GreenReaper93
Hey guys! I didn't want to hi-jack laniac's thread, but I'm having an oil issue as well. 4.0 with an AX-15. When I start the jeep the pressure is somewhere around 60 psi. With about 5-10 minutes of driving it drops to 10-20 psi. I know it's normal to have a pressure drop due to the oil heating up, but here's where I get nervous. After 10 or so minutes the pressure bounces around 2-15 psi. When at idle it's at 2 and when I rev up at a standstill it can jump up to 15-20 psi at just over 1k RPM's. I've already changed the oil sending unit and it didn't seem to change anything. What's next? I'm assuming it's a toss up between the oil pump and the cam shaft bearings.
I'm not going to rule out the gauge...but it seems like an unlikely culpreit. Thanks!
