If you have a bleeder valve on the slave cylinder area, install a short vacuum line going to a half full glass jar with a clean fluid. Open the valve, top off the reservoir and slowly press the clutch pedal all the way down and slowly release all the way up. Make sure the vacuum line on the bleeder valve stays submerged into the clean fluid and the reservoir on the master cylinder stays full. Do this procedure 5 times and repeat as nescessary. Last week i worked on a 92 YJ that has no clutch pedal engagement at all to the slave cylinder. I topped off the master cylinder reservoir and pumped the bejesus out of the clutch pedal until it primed. No problem since. This may work as well but try the first one before you do this..Consider a possibility that your master cylinder is not creating the pressure needed to bleed the system.
