hoobness
So I've finally been able to drive this thing. The steering is much better than it was when I bought it, I've replaced the steering shaft with one with u joints top and bottom, replaced all the steering box mount bolts with new grade 8s, the front shackles and bushings are OEM replacements, one ties rod end was replaced. Its a lot better, but still has issues.
Quickly I noticed when I was bleeding the PS pump (front off the ground) the whole front end shifts side to side as I'm trurning lock to lock.
It has lift(arched) springs I believe. Rather an SOA, but maybe later.
The way the factory designed steering box setup is mounted is part of the problem. I'm sure its fine without those springs and stock tires but man its a wobbly old thing.
Today I'll think about adding a steering stabilizer to start. I'd like to reinforce the whole steering box mount. Do they make something that does this? I can dab one if I need to but in 35 years of wheeling this product has to be out there. I can't be the 1st to notice this. Anyway, that's the new problem I have.
Have a great weekend everyone.
