Hi-Ya Laura and Joe,
I would like to attempt helping out with your wiring problems, but helping is difficult because I am confused. It might take several posts to get a handle on the problems.
I guess I need to have some questions answered.
Q-1: I asked early in this thread if this was the Jeep with a Chevy SB-350 engine that Joe recently purchased, but that question was never answered in the succeeding posts.
I asked that question because modifications to the original Jeep wiring harness would have been necessary when the SBC-350 was installed to replace the original engine. Unfortunately, that engine swap, in terms of wiring, is not a simple "plug and play" situation.
So....if you guys go with the "Painless" wiring harness solution, will "Painless" make up a custom harness for a 76, CJ with a Chevy SB-350 engine? If not, and only a stock 76 CJ replacement wiring harness is available, then you guys will have to modify that brand new Painless harness during the install to make it compatible with the SBC-350. Is that where you want to go?
Q2: The situation Joe mentioned with having to jump-start the CJ after six tries at starting and the smoking negative battery cable is obviously abnormal. Can you elaborate on that problem? When (during what conditions) does that happen?
Q3: Joe mentioned having a toggle switch on the dash to control an electric fuel pump. Is that switch still needed and functional? If not, then how is electrical power now being delivered to the electric fuel pump? (This is one of the electrical complications resulting from the SBC-350 install. Will Painless make up a harness that incorporates a key-on hot provision for the electric fuel pump?)
I have more questions, but the above are likely going to cause an overload, so I will stop here -- for now.
The dash lights, directionals, clock, blower motor problems are minor and better dealt with later.
Regards,
Gadget
