Ok I have an 86 cj7 with the 258 4.2 liter. Clifford 4 barrel intake and holley 4 barrel carb. I recently put a cam and lifter kit,new carb, plugs, wires, cap, rotor and coil. I also did the nutter bypass. The problem i'm having is when take it for a drive it runs great until I come to an idle. It pos and misses and sounds horrible. However it still remains very responsive. If I let it sit and idle for a few minutes it eventually clears up until I go drive it again. What should I do? Could this be a ring or valve issue possibly?
Thanks
Casey
Thanks
Casey
