CJ 5 with tire size 35"
javcamac
Hi guys.
Any one know what I need if I going up to size 35" with 20"ring.
what kind of shackles, leaf, spacer, all of those stuff.
By 20" ring, are we reffering the the rim diameter? And what size is the width? Does the rim have any back spacing (off-set)?
It 33x12.5x20
I feel the jeep unbalanced and I think I miss something to add. I already have high shackles, single steering damper (maybe I need to add dual shocks). I have 1.5 spacer on chassis.
The long shackles are a bad idea and will lead to a lot of problems like steering wander, axle shift, improper pinion angle, the feeling of unbalance. Consider stock length heavy duty shackles and a spring-over axle conversion. At the very least a 4" spring-under lift kit with new spring and shackle bushings.
