Hi there
I have a problem that still unsolved by the experts.. My standard 94 4.0L shuts down after 30 min, the problem is narrow down to the "auto shut-down relay" which overheat and when I want to restart doesnt start, when I change the relay start fine and the cycle continue...
Actions and status
Gabe
Actions and status
- all the relays are changed twice in 2 different brands (germans and Americans) thats why I can change them all the time
- The balast resistor relay overheats aslo but does not cause the problem unless is very related with the problem
- the balast resistor has 1.1ohm is ok but runs hot (I dont know if this is normal) the drop voltage is at 10V to the pump.
- The most important part: if I open the balast resistor the engine does NOT stops just run with difficulty but never stops, as per the diagram this is imposible a low rpm because the balast resistor relay must be off, then there is a problem here...
- The radiator fan runs all times with the coolant sensor new and A/C off
Gabe
