1053412
Like Jeepin Madness said, a hook up straight to the battery is a good place to start (and recommended by most manufacturers)(Battery acts like a giant condensor). Noise suppression kits can also help, but are often set up for specific RF frequencies, if you get one, that doesn´t filter the frequency your vehicle is generating, you´ve waisted some money (radio has it´s own filters). Ground is also a good bet and also putting as much distance and/or metal between the source and the antenna is also preferable. Generally speaking, it sometimes requires all of the above to do away with the noise. Good shielded and grounded, antenna wire and connectors and not laying the antenna wire in loops helps.
Filter kits that hook up straight to the ignition or the alternator, are to be avoided, if they fail, so does what they are hooked up to, sometimes.
Have someone in the know, set up your SWR (standing wave ratio) for you, helps the CB to last longer and is required with most guarantees (keep the reciept).
Read the book, play with the squelch and have fun :-D
edited by: MudderChuck, Feb 03, 2003 - 03:44 AM[addsig]
