Carb rebuild time
Jeepster05
I think it's about time to rebuild this carb of mine. My dad says "it only gets worse when you rebuild one". But I'm gonna go ahead anyway. I called a carb repair place and the a hole wanted $265 to rebuild the thing. uhh i dont think so pal. So for 20 some bucks I'll just do it myself. I'd like to keep my record anyway of never putting her in the shop and doin the old fashion way.[addsig]
1066636
You are wasting your time rebuilding the Carter carb on the 258 engine. Better to invest in a bolt-on Weber replacement.[addsig]
1066652
a cheaper alternative to a weber carb (and just about as good) is a Ford MC2100. Theyre practically bombproof and you can find them anywhere for cheap, and theyre easy to maintain and service.[addsig]
1066668
Bounty Hunter's opinion, in my opinion, (lol) is only partially correct. Installing other brand carbs or even fuel injection may be a better way to go, but some of us live where those changes are not an option for smog reasons and others it’s just the cost.
I have a 4.2 with over 250K miles (Original carb rebuilt) that runs great daily on and off-road including the hours of rock crawling at slow speeds in all kinds of positions (Hopefully not upside down)
Your Dad's opinion, again in my opinion (lol) is correct, but with an explanation.
Some carbs are so difficult to repair that trying to rebuild them correctly by untrained mechanics causes more problems than when you started. (Buying a new part is always nice; then again why throw away money if you don’t have too) These Jeep carbs are simple to rebuild if you can follow instructions your fine. Parts do wear out but if done correctly...Well, 250K+ miles speaks for itself.
I have used those $10.00 rebuild kits with $1.89 cans of gumout for years with great success including my Carter BBD. (Having a carb without damage is a plus). They do wear out but I am surprised on how long the can last too.
It's easy to blame the carb for performance problems, but there are many other things that need to be looked at before placing that blame. Vacuum hoses are a biggie. Not only incorrectly routed but plugged off, missing or just plain old and leaking. Electrical connections or broken, incorrect, or missing wiring, Spark plugs, wires, caps and rotors, etc. Late 80’s Jeeps with carbs have so many systems designed to pass smog that any one of them not operating properly can cause performance problems.
I have seen Jeepers tearing their hair out trying to solve a carb problem just to found out it was a bad coil wire. (Stuff Happens)
As for the carb rebuild: It's a cheap repair that's worth a try and keeps you record going.
As for installing another system: That's also an option, but which is really the best? And at what cost?
Jeepster05.
There is a plus to doing your own work. Jeeps are different from most other vehicles in that we go to places that are far from repair shops and towing is tuff. Anything you can learn about your Jeep systems helps you and others when problems occur on the trail, saves money and it’s just cool to fix it yourself.
Knowledge has saved me many times.
Good Luck. 8-) [addsig]
1066700
sure you can try and keep that carter running.... but why? If we were trying to keep all of our stock equipment on our jeeps, why would we do engine swaps, lift kits, all sorts of body mods, etc etc. If your gonna replace your carb anyway, why put a carter back in??? Note, a Ford MC2100 carb is a very good one, very cheap, and you can find them in almost any ford in a junkyard. Weber's are the obviously the top of the line. I doubt putting in either of those would keep you from passing emissions. The carter just isn't worth it. yeah you can keep it running, but your jeep could do so much more with a better carb. [addsig]
1066716
I've heard great things about the Motorcraft carb, worth finding one. Heard they work really well on hills and off-camber too.
I've heard the Carter can develop an internal crack, forget where, that a rebuild won't help. Kinda like polishing a turd :-O [addsig]
1066743
Ive got an 87 with a 258 and junky carb. What year model and what types of Fords were these motorcraft carbs on? Ive got plenty resources fora Ford cab.[addsig]
1066769
Here's a link to some info about swapping on a 2100...
Motorcraft 2100 Swap
If you're like me though, and live in a state like VA that treats emmissions inspections like you're putting national security at risk, then you CANNOT swap off the BBD for anything short of fuel injection if your Jeep is under 25 years old.
I personally am not willing to swap off the BBD for anything short of MPI anyway, but thats somewhere in the far off future. I recently had my mechanic overhaul the stock carb and my CJ is running smoother than it ever has since I bought it. IMHO, rebuilding the Carter BBD is worth a shot.
jim[addsig]
