I went to check out a 95 YJ in my area.. everything looks to be in good condition except on the drivers side, the leaf spring shackle is bent parallel inwards. If it's jacked, is it possible to remove and bend the shackle back to it's normal position without too much work? I'm sure this will become an issue if it's ignored, but then again, I don't know much about leaves or the removal of them.
Thanks in advance.
Thanks in advance.
