Built Axles Setup SOA for a YJ
csudman
Waggy 44 Drives Side Drop
You cannot build a front axle anymore than this one is. There are over 3000.00 in parts in the front axle alone, that doesn't include labor to assemble this thing.
ARB Air Locker
The inner axles and one of the outers is brand new from Superior. (The other outer is also superior) These are the america made best on the market shafts avalible for a dana 44.
Longfeild 300m U-joints
High Steer knuckle and arm on drivers side. Passenger side has new knuckle, just needs new arm.
Warn Lockouts
4.56 Gears
Setup to run SOA in a YJ with a new Ruffstuff Simple Axle Swap kit - New u-bolts and spring plates come with this axle.
Rear Axle - Isuzu 12bolt
4.56 Gears
Factory Disc Brakes
$2000.00 OBO for the set.
Check the rest of my threads for more parts.
