Joopin
Super Moderator
1071794
a couple weeks ago I changed my valve cover gasket and cleaned the whole top of the engine. I noticed today when I was changing the oil that the rear of the valve cover seemed to be leaking and going down the side of the block. I tested one of the bolts to see how tight it was and it didn't seem tight at all! So i tightend it and went onto the next one, then the next one... and then one broke! It didn't even seem tight! Anyway, I hope to drill out the bolt and tap the hole WITH the cover still on...
So do you think it will cause a problem if I drive around with a bolt broken? Does anyone have an idea why it's leaking in the back of the valve cover? I know that the bolts have to be equally tight, with a torque wrench, but I dont' have one... I guess I should buy one so crap like this doesn't happen.... This just makes me want to rebuild the engine! 195k and counting...[addsig]
