bugleboy
delta said:Bad idea like jester said you need to either replace your stock leafs for oem spec leafs or get a lift with a full pack an AAL will just last you a short time and then you will be at the same place you started you might look in to ******* packs if you don't want new springs it might help for a longer. What distance are you getting from the center of your rim to the bottom of your fender flair
i meant the lift that includes the add a leaf, the stock leafs are fine its the fact that the tires are to big and theres not enough clearance to carry much weight
