Hi my jeep is a ZJ 1998 grand cherokee laredo 4x4 I6 4.0L engine
I have had this problem for long time now, found treads here and in other forums about similar problems and there fixes but they have not worked on mine the last one i did is I took it to a shop the said it was the PCM but it is only 2 years old I got from a dealer..
symptoms
I turn it on leave it Idling and after about 10 mins it turns off.
while driving the RPM goes to 0 in then it turns back on wiht i big kick if i dont let go of the gas. i f i let go whern the RPMs are at 0 it will shut off..
i have to wait a minute or two before it turns on again. if i try to turn it on as soon as it shuts off it wont turn.
after checking the codes i have gotten a couple from 351 (coil primary circuit), evap leak and others I attended thos codes
but a new coil, cleaned a lot of the connectors for various sensors.. and still the problems remains this last sumer the problem seemed to go away after routing some of the cables but now that the weather is cold 48~55 ºF it started again
any help will be appriciated THANK YOU
symptoms
