SteelHeadz
Super Moderator
:-|Subject: New Military-Grade Jeep Dana 60 and Dana 44 Axle Assemblies
Available exclusively from Mopar Performance - Jeep Wrangler military-grade front and rear axle assemblies for Jeep Wranglers. These tough, genuine Jeep assemblies are designed for the military Wrangler J8 and provide the next level of off-road performance for Wranglers. They come fully assembled and well equipped with 4.10 gears, JK wheel speed sensors, and massive, heavy-duty disc brake calipers and rotors. The high-pinion Dana 44 front axle is ready for bolt-in on all 2007 & newer Wrangler’s. The Dana 60 rear axle is configured for leaf spring mounts*.
Specifications:
Axle Ratio: 4.10
Wheel Mounting Surface Width: 65.4â€
Wheel Bolt Pattern**: 5 on 5.5â€
Rear Axle Tube Diameter/Thickness: 3.5†/ 0.35â€
Front Tube Axle Tube Diameter/Thickness: 2.5†/ 0.31“(25% thicker than JK Dana 44)
Rear Brake Rotor: 13.8†Diameter x 0.87†Thick, Vented
Front Brake Rotor: 13.25†Diameter x 1.1†Thick, Vented
P5155083 - Jeep Wrangler Dana 60 Rear Military Axle Assembly, Leaf Spring Mounts, Limited Slip Differential, Large Disc Brakes, 1.5†– 35 Spline Axle Shafts
List: $2995
P5155084 - Jeep Wrangler Dana 44 Front Military Axle Assembly, 2007 JK Suspension Mounts, Open Differential, Large Disc Brakes
List: $4495
These axles are an outstanding upgrade for off-road use and those planning to run larger tires. Tell your off-road Jeep enthusiast about this exclusive offer from Mopar. Upgrade those stock axles to military-grade Jeep axles today!
* Adaptation of the rear axle to fit the suspension of any Jeep vehicle is the responsibility of the purchaser.
**5 on 5.0†Wrangler wheels will not fit these axles. Commonly available 5 on 5.5†x 16†or 17†diameter wheels are required to clear the large brakes.
Specifications:
Axle Ratio: 4.10
List: $2995
List: $4495
