Axle options
Sully
I've thought about this for awhile and was just wondering,what would be a good front axle swap???If you are running 33's will the stock dana 30 be strong enough???I know that the amc 20 in the rear would be pretty tough if you put in a solid axle shaft.But,what do you put up front??? Sully[addsig]
1071871
the 30 will be strong enough for most people... it never sees the torque that the rear end sees.... but.. if you plan on doing some extreme wheelin... then you might want to upgrade[addsig]
1071923
if you only are runnin 33s the front and rear will both hold up, if you put one piece axles in the rear......that old 258 just dont have to grunt to bind them unless you co really nuts[addsig]
