ax-15 in a short grand Cherokee
Kabeatty
So I'm new to these forums, go easy on me. I bought a 96 grand Cherokee limited. Has the 5.2V8 engine. Transmission died on me the day after I bought it ( I was planning to swap it anyways just not so soon)
my question is, would swapping in an ax-15 affect the towing capacity at all? I plan to use this Jeep to haul a 3,000lb-4000lb camper once I get the transmission fixed up. I would much rather have a manual transmission anyways but I'm not 100% certain if doing a manual swap will allow me to keep my 4X4 and towing capacity.
Any help at at all is greatly appreciated
You will need a 4wd ax15, be sure the output shaft matches your transfer case input.
Your towing capacity will be unchanged.
