Automatic tilt steering column CJ7-81"
javcamac
Hi guys,
I need to repair or replace my Automatic tilt steering column from my CJ7. I try to adjust the torx head fasteners the secure the lower tilt housing to the column but I think that the housing base are damage.
I tighten them but isn't work. they adjust to the fastener but the housing still moving like a swivel tool.
Some one have the experience in that kind of issue.
How to repair the base or maybe swap to chevy stering column...
Need Help!!!
Thanks...
any really from a car or truck, the van ones won't work. just find one with a column shift, regardless of the yea rmake model, you will have to probably re-pin the ignition harness. you can also use a YJ column. most chevy, dodge and jeeps in the 70's and 80's used the same saginaw columns.
I only mentioned these because CJ with auto shift column and tilt will be hard to find simply because their were less of them.
