Never had a problem with the bearing, but I know when the axle snaps its usually on the drivers side. Could be the axle tube is bent and it's putting stress on the bearing. Amc 20's are notorious for weak axle shafts and tubes
Every AMC 20 that i've been around that has repeated trouble with axle bearings has been because the housing has some form of damage. Twisted or bent axle tubes.
