Baseline 4x4
All Alloy USA Axle Shafts carry a 10 year warranty. Constructed of 4340, these shafts are up to 40% Stronger than OEM Shafts.
-Front and Rear applications
-Stock Spline Counts and increased Spline Counts
-Alloy USA Axle Shaft Application List
Alloy USA Axle Tube Seals are designed to keep water, mud and debris from entering your front axle housing. These CNC machined aluminum housings feature two seals to provide double protection from the crud.
-Sold as a Pair
-3 year manufacturers warranty.
-Rebuildable
Click Here for Alloy USA Tube Seal Kits
Alloy USA Heavy Duty Alloy X-Joint, Complete U-Joint With Bearings 760 Style
Heavy Duty cold forged Alloy USA X-Joint is a complete U-Joint with bearings. A seriously beefy upgrade for Dana 44 style U-joints applications. Replaces factory Spicer u-joints 5-297X and 5-760X. Serviceable grease Zerk at each cap allows you to flush grime and fill with grease to ensure that your X-joints will last for when you need them. Dependable cold forged steel composition made of chromium, molybdenum and nickel alloy. Hardened case for excellent wear resistance. Full circle clips as well as half clips included.
Alloy Usa Yoke Conversion Kit with Spicer U-Joint and U-Bolts, 76-86 Jeep CJ
Converts standard strap and bolt style yokes to much stronger u-bolt style yokes.
AMC 20
Dana 30
Dana 35
-Sold as a Pair
-Rebuildable
AMC 20
Dana 30
Dana 35
