air conditioning.
albacore00
Replaced ad compressor. Purged system and recharged. Ac works fantastic. So much condensation water pours out of lower ventilation into cab at my feet. How do I fix this?
Welcome to jeeps.com . Glad your air conditioning system is working well. Good job ! As far as the problem of water overflowing into the cabin , look for the drain line on the passenger side of the firewall . It will be a rubber tube that points down. This tube drains water that finds its way into the vent ducts . The presence of water should only be from a/c moisture that is wicked from the cabin from humidity . There should be no leaks from the hood vents that will cause water (rain or car wash for example) that can infiltrate the vent ducts. To clear the tune , reach up from under the jeep and poke something that will reach into the tune to clear any dirt that has accumulated in the tune and duct. You may take a garden hose if you can reach the nozzle into the tune but do not spray a lot of water into it. You only want to apply some pressure to,clear the block and help to wash out the duct. Let all the water drain and repeat CAREFULLY to clean thoroughly . Also , clean out the hood vent of any debris ( leaves and dirt from windshield , etc) to clean vents as well. You may spray some water from the garden hose , again , CAREFULLY , from the hood bent where the wiper arms mont to help clean the vent but only after the drain is clear. Use water sparingly and watch under dash on passenger side floor for leaks. Lastly , dry up any standing water UNDER the carpet or mildew WILL result.
