94YJ 2.5L with automatic transmission. Pulled the air cleaner box and Hose to the throttle body, the Hose was caked with oil and crud. Cleaned it out, then pulled the tube from the PCV valve to the hose it was pretty filthy, so I cleaned it also along with the throttle body. Purchased new PCV valve Rubber Grommet and new air filter, but was told that valves and rings are bad because there is oil in these places. Now the question is fact or fiction? Any thoughts?
