TwistedCU
Active member
Well the system is completely dead again. I am told by some that it is likely the evaporator. I don't knoiw how much they cost but the job is rather labor intensive - complete dash removal, etc.
I decided to disconnect the AC to avoid the annoying short-cycling while using the defroster this winter. I tried the under the hood fuse, the under the hood relay (both removed). The compresser clutch did not engage when I turned the AC/defroster on, but the idle still increased.
After fooling around for a while I figured out the best way to disconnect the AC completely is to unplug the connector on the tube just behind the top of the compressor. All relays/fuses can remain in place. The idle stays normal and the compressor clutch does not engage.
I thought I would post this because there was someone asking about the best way to disconnect the AC recently. It also might be a seasonal thing to do to save a few MPG and wear and tear on the AC system through winter months. I may plug it in once a month and run it a while as I've been told that long periods of non-use can be bad for the compressor.
