TwistedCopper said:
XJNick said:
Just my $0.02 but I think you had/have a leak. They are very hard to detect if they are small and/or in hard to see places (such as leaking through the barrier hoses, evaperator coil, etc..)
-Nick :!:
Well Nick you were right, I was wrong. Blowin hot air at me again
So if the garage says they didn't detect a leak, isn't there a dye I can have put in ?
Leaks are often so small they can take months to be noticed, a fast leak is usually in the high pressure side. Generally takes 10-15 years for a system to loose enough freon through osmosis, for it to be noticeable.
Usually leak at a joint or fitting. 134A is hard to test, they are turning out new testers for 134A, most every month, few seem to work well.
The stain method with the UV light works well, if it´s someplace that you can see. Leaks in the evaporator (heater A/C box) sometimes take a lot of 134A with stain, to show up on the carpet.
Unless your willing to pay somebody to look for a leak, by the hour, I´d put some pressure in the system and soap all the joints I could get to. Visually inspect the whole works with a flashlight, closely, for oil stains (freon is mixed with oil). If that didn´t produce any results.
Then push a little R-22 in the system, and use a good old fashioned freon leak detector, to at least narrrow it down to an area (like inside the heater A/C box.
If you have a leak, chances are your gonna have to vacuum the system and refill anyway, a little R-22, isn´t gonna hurt much and a lot easier to detect.
