1065899
so i am having a NASTY time trying to get the a.c. pump {a.c. in a jeep ?} disconnected from it's bracket. i want to rebuild it so i can turn it into a on-boad air set up but i can't get the bottom two bolts out. the nuts are off but the bolts WILL NOT budge. i tried wrenching 'em with a 1/2'' drive breaker bar but that did'nt work. tried tappin on the end with a hammer to try to free it up but that did'nt work. using a bigger 1/2 '' drive 12point socket was a tight fit under the pump pullys, so to gain a slightly better fit i would like to remove them. anyone know how i can get them to stop free-spinning so i can remove the center nut ? better yet, someone tell me what's going on with those freakin bolts before i fire up the cutting torch!!!!![addsig]
