Bomberbeer
Hello, I'm new, i apologize if this has been asked before.
I am banging my head against the spare tire in frustration.
My 98 Wrangler (4.0L, 6 cylinder, stick) has 290,000 miles (yes, 290,000) and last year (winter wasn't so bad then) my thermometer gauge slowly, over time, crept leftward from the 210º mark, and is now past the "\" mark and heaed towards 100º. The engine does not heat up to the "expected" level.
Two years ago the Water Pump failed, and Firestone replaced the water pump, belt, and radiator fluid (but not the thermostat).
Two weeks ago i replaced the thermostat with an OEM grade 195º replacement. truth be told i had never done it before, so it took a while, and i had to use two gaskets to get it to seal right.
I was told afterwards i probably had an air bubble in it - so i parked it on the incline of the driveway, and added more fluid when the thermostat opened and the fluid level went down. I capped it off.
The temp gauge remained the same - at about 150º. not very exciting, and not very warm in the passenger area, either.
I checked the hoses, and when the jeep is running at "max" or "operating" temperature, the main hoses are warm, and the hoses leading to the heater core are both hot (the one going in and the one coming out.
Last night i tried replacing the radiator cap with a new one - it fit much better, but it did not solve the problem either.
I believe i am doing something wrong, but i dont know what. When i took it to a local mechanic last year (when the gauge was below 210, at about 190) he said "you have heat, it is fine.
I know it wasn't fine. My Jeep always felt like it had a pipeline to Hell, because it blew some seriously hot air all through the 1998-2006 time frame.
The heat had been loosing it's OOMPH before the water pump failed. Ever since, it hasn't gotten better.
To recap:
98 Wrangler 6-cylinder Stick (no Air Conditioning)
New Thermostat
New Radiator Cap
Fluid is moving in radiator
Thermostat opens and closes.
Hoses to Heat Exchanger seem to be working.
The Gauge never shows it going up to 210º
There is very crappy heat coming out.
Please tell me it is something as odd as "you have a blown fuse" or something.
Dan
To recap:
New Thermostat
New Radiator Cap
Dan
