Have been researching probable causes why the P1391 code is setting . We already know it pertains to CMP (cam) and CKP (crank) but was also mention which is not surprising about slack in valve timing. I know where we stand with that . Was also thinking a worn distributor but that usually results in rough idle/ stalling and in extreme cases , no start. As it stands , your PCM has no trouble finding the DTC 1391 . Rather than think worn distributor , I would concentrate diagnostically on valve timing. To update , I incorrectly posted there are no timing marks on the 4.0 liter engine. There certainly are ! I verified that on mine. I just never refer to it as timing is not adjustable as previously posted. Sorry for that . I was celebrating my success to fixing the leaking high pressure trans line on my '92. All better now , thank you. The jeep as well.
What I will suggest ( trying to give free advice $$) is when this timing chain slack test is performed that the distributor cap be removed and note if rotor tip out of position with crank movement. I'm sure it's installed correctly if was removed for CMP sensor repair or the jeep wouldn't run. I wouldn't attempt to advance distributor timing to compensate for timing chain slack as it is likely to make things worse . Not only am I thinking DTC code but am also focusing on the actual drivability glitch your experiencing . It's around the time the trans shifts into overdrive . I'm not yet faulting the trans control module since this is at this time thinking out of the box. Thinking more that it's rpm related. Trying not to think too much and just focusing on the valve timing error possibility. As long as the PCM is feeding both crank and cam sensors 8 volts and the ground is good , valve timing slack is my hypothesis / prognosis , call it what you will. Also being sensitive to your dwindling funds as well. If all that is wrong is a worn timing chain set and tensioner , aside from $$ , hoping there is closure and you'll be cruising , smiling and blasting tunes in that order. Well , it's Father's Day and wishing a happy to the fathers in your life and hoping I'm on to something . I always believe in fixing the obvious before moving on diagnostically or further checks and testing are fruitless. Visual inspection such as damaged wiring or any noticeable damage and wear goes without saying. I hope this helps and still hold hope that you'll be able to drive your beloved jeep soonest . Feel free to look for any live stream data that may seem related . For example , sensor signal voltage and reference. I know I've just thrown a lot at you but approaches methodically and in steps , justice will prevail. I know , diagnostics are fun . Most think you have to be sadistic or without a life to focus on these lengthy procedures but I've actually accomplished successful trouble shooting before within my understanding and believe anyone with proper equipment ( computer safe test light , computer safe digital multi meter , a scan tool is nice ) can do this with nothing more than good reference ( shop manual ) and intuitiveness . Whenever I have a problem which prompts me to throw the nearest wrench at the nearest standing object , I know its time to drop it for now and father a new stragety . Wishing you well and lighting a candle and a Hail Mary all will be well soon. Greg
