Scottie
I tried to replace the standard bulbs with uprated ones in the side/parking lights. According to the handbook and recently purchased Haynes manual - you remove the top (Torx) screw which is easy enough - then the bottom screw which is blocked by the front repeaters !.
So I shall remove the repeaters I thought :-| according to both manual and hand book the screws are located - below the side/parking lights :shades:
Do Jeep fit the front lights at the factory and assume that the bulbs will last the life of the car :???: because it appears to be impossible to reach the bulbs !.
