94 wrangler and cherokee interchangeable parts
Gennybro
Active member
Have a 94 wrangler and a 94 cherokee with the same 6 cylinder engine. Was interested in finding out what parts from the cherokee would be compatible with the wrangler. The cherokee is a rust bucket, so if I can use parts from it for the wrangler,steering gear box for example.
Are you looking what to keep or specific parts you need to swap?
Like engine with PCM
Steering box
Drag link and tie rod
Axels may need work on front.
Trans and transfers case
There are some ways to verify on a mopar site. Look the part up and it shows compatibility year and model.
Just curious as to keep the cherokee because of parts that may be able to be used on the wrangler, thanks.
