89YJ power steering Help
PS89YJ
What I have is an 89YJ 4.2 with 95 fuel injection and stock suspension. I want to add power steering. I’m being told I can’t mount the pump because the intake manifold does not have any means to bolt in the pump or brackets. I have idler pulleys on top left and right. I can’t be the first to do this, is there any place where a bracket can be purchased that will enable the pump to be bolted on or do I have to fabricate one?
Paul
I think someone BSd you. Look at the casting number on your intake and one that has PS. They should match
No BS the manifolds are very different. I added the injection with a Mopar kit so it is not a stock manifold the mounting holes for the pump are not there. I have figured out how to do the change to power steering and now have the necessary parts but will have to make a rear bracket to help support the pump. Maybe this weekend.
