1042212
I have a 1988 Jeep Cherokee. The right rear axle seal is leaking all over the drum brake system parts. I've taken off the 4 bolts that hold the brake backing plate to the outer axle case. The Haynes manual says the axle should pull out but I can't get it to budge
. Is there anything else preventing the inner axle from pulling out? Do I need a special tool? thanks for any help.[addsig]
