4wd switch
jeepers x2
I have a 95 grand cherokee limited and at any time while i am driving the info center will beep 3 times and then it will read service 4wd switch. Where's the 4-wheel drive switch? It's a full time 4-wheel-drive vehicle. What gives?
It should be attached to the transfer case, look for the wiring harness leading to the case.
Just in case you do replace the 4wd switch, heres the procedure to reset the EVIC,(Electronic Vehicle Information Center). To Reset, turn ignition on, press the SELECT button, then press the SET button for 2 seconds to reset the service interval.
