to ask the question, i have to tell you first were i'm at..
i have a cj 3b the stock gears at as follows 1st 2:79 4 lo 2:43 diff 5:38 total 36 to 1... i'm upping my input shaft, and gear cluster to get 1st up to 3:44. i want to do a tera 3.15 gear set in the dana 18 with the diffs 5:38 that take me to 58.29 to 1 pretty much were i wanta be.. for teh trails i'm looking to do..
the problem is i have the smaller 3 1/8" hole, and need the bigger 4" hole dana 18 to make the gear set work. will that 4" hole work with my t-90 3" out put bearing? i have not scene a 4" out put bearing to convert this over so i can run the new t-case with the lower gears... i wanta have answers before i buy the newer 4" hole dana 18 case...
thanks
thanks
