I replaced the resistor when I replaced the fan. I checked the old one before I ordered the fan. It read out ok but was pretty heavily corroded. It was cheap so I figured I might as well change it out. After further inspection, I found that the one small connector with 3 wires was melted along with the wires going to it. Once I removed it I could see the circuit card was burned up too. The terminals on the back of the blower speed switch are melted. The previous repair replaced the connector with spade terminals which weren't insulated very well. They may have been shorting together. I was able to find the panel on rockauto. Just need the small 3 wire connector. Id like the 5 pin connector for the blower speed switch, but can get by with spade terminals if need be.
