superj
Well-known member
And a longer flatt screw driver against the driver side bellhousing and ypu cam put the tip in the flywheel teeth to rotate the engine over and get the 4 bolts holding the torque converter to the flywheel.
Ours is done. Jarrod took the jeep for a few test drives and after we changed the fluid once it was installed and it rauns great so he took it home. I have the 97 blue tj now
