91 Wrangler odd brake parts
a46342us
Yes I tried to swap out my caliper and rotors today along with the pads...After a long day and three part stores later I still can't find the size.
The rotors do not match up nor did the pads... The caliper brackets were stamped with AMC, tried looking in other Chrysler products around 91 as well. I do have a pic should you need it
When you say that it doesn't match up, do you mean that the brake pads won't fit into the caliper, or that you can't put the caliper and pads onto the rotor?
The ear on them is not deep enough to seat the calipers...
I think I've determined that I have a Dana 30 front end and I was attempting to put stock parts on it. My rear end was off an 88, am I safe to assume that the front end was off same vehicle? But then how do I get parts for this front end locally?
Caliper
Axle
Pad
Upper Ear
