:???:I have a 97 TJ 4.0 3 spd auto, my starting problem is driving me crazy trying to find,it has been doing this for 6 months now.I try to start jeep it just turns over doesnt fire even if you crank for 30-45 seconds,release key from start position and retry to start it fires rite up.have changed cap rotor wires plugs clean air filter.i have noticed that when you first turn key to on and let the gauges cycle i dont here the fuel pump but when running if you listen close i can here the fuel pump working,about the same time it developed off idle stumble that only happens once within 1-1.5 minutes of starting then runs fine.this is more of an annoyance than anything any help would be appreciated
