Jeep 258 TFI ignition upgrade - Using stock Ford parts, you can upgrade the ignition in your Jeep, allowing much better performance, gas milage, and reliability
Which engines can use this upgrade
The Jeep 258 CID I-6 from 1978 to 1990
Why would you want to do this?
Before I did this upgrade my jeep would not idle, it would hesitate and die all the time. This upgrade gave my Jeep the feeling of a new engine! It idles fine (even with the carter carburetor) and has more pickup and no hesitation. I would imagine that my Jeep now gets better gas mileage and has less emissions (although I have no real proof of this). Plus this upgrade only costs about $100. The upgrade is said to be better than the HEI.
What you need:Distributor cap, rotor, base (this distributor is a two piece type, with a base that mounts to the motor and a cap that clips to the base), spark plug wires, and ignition coil. All these parts are from a 1982 Ford F-150 Pick Up Truck With A 300 CID I-6 Engine
OPTIONAL : Distributor centrifugal advance springs, these get installed in the distributor and give you more midrange pickup.
