Latest activity
  • Turbogus
    Turbogus replied to the thread Black Betty no start.
    Thank Terry, I'm being criticized on another forum where a couple of kind folks insist this is a fuel issue. With the double whammy of...
  • TerryMason
    TerryMason replied to the thread Black Betty no start.
    That's great man. I'm glad that you are pointed in the right direction.
  • TerryMason
    TerryMason reacted to Turbogus's post in the thread Black Betty no start with Like Like.
    Okay I grounded the Starter Solenoid and she spun up just fine. I removed the Cap to the MSD and watched the Rotor make several turns...
  • superj
    superj reacted to Turbogus's post in the thread Black Betty no start with Wow Wow.
  • superj
    superj reacted to Turbogus's post in the thread Black Betty no start with Like Like.
    Knulla she won't turn over at all now. edit Vittu Minua, I forgot to ground the Starter Relay
  • Turbogus
  • TerryMason
    I've got the shroud / gasket on the radiator, and it's not cut or broken (I actually just replace that too). I've got a Motorad...
  • JPNinPA
    JPNinPA replied to the thread Post weekend frame flush.
    https://youtu.be/Ewu3mNCANPI?si=GB6FXDM4ieYixTWx Never look down on anyone unless you are helping them up - Jesse Jackson
  • JPNinPA
    I’ve seen people use this method. https://youtu.be/Ewu[emoji639]mNCANPI?si=GB[emoji6[emoji640][emoji638]]FXDM[emoji640]ieYixTWx...
  • JPNinPA
    Well that is why I chose it. That is what this forum is about. Never look down on anyone unless you are helping them up - Jesse Jackson
  • JPNinPA
    Yes Knoebels is awesome. It was app...
  • JPNinPA
    Holy thermo is important even if you drill the hole. So I had overheating while sitting with no boilover. That was the issue. Pressure...
  • superj
    superj reacted to JPNinPA's post in the thread Post weekend frame flush with Like Like.
    Check this out. https://youtube.com/shorts/cxLBTvXofFA?si=W6nDD6w_3AXxwIq8 Never look down on anyone unless you are helping them up...
  • TerryMason
    TerryMason replied to the thread Post weekend frame flush.
    I think this may be it (or at least similar) https://www.amazon.com/Salty-Captain-Chassis-Grenade-Undercarriage/dp/B0DZ8QK3GS/
  • TerryMason
    That's awesome. I hit mine with the pressure washer every now and then, but that looks like a much simpler (and maybe more effective)...
