Latest activity
  • prariepunk
    prariepunk replied to the thread Old member 2001-2004.
    I was just thinking about Mud4feet after finding an old CD he burned for me.
  • C
    christmasmeadows replied to the thread Help Please.
    yes it is from factory, there 3 connectors total, 2 passenger side and 1 drivers side.
  • TerryMason
    TerryMason replied to the thread Help Please.
    Thanks for the followup. Is this a factory connector (as far as you can tell)?
  • C
    after fiddling with it all day, i got it to come loose. this connecter has 2 tabs one on each back side on inside of connector box. you...
  • TerryMason
    Did that do the trick? I assume that you're supposed to loosen the bolt first, then pull on the white fingerhold.
  • TerryMason
    TerryMason reacted to superj's post in the thread Help Please with Like Like.
    Put your finger around the white part and pull hard. That may just be for pulling on
  • superj
    superj replied to the thread Help Please.
  • C
    i have a 2012 jeep grand cherokee i am trying to disconnect the wiring connector and unable to take it off. i have gone to jeep...
  • J
    Hailing from Cajun country, I've seen firsthand how even the most rooted traditions can blend with tech—thanks to tools like Google...
  • M
    mark sr reacted to JPNinPA's post in the thread 1986 CJ7 wondering with Like Like.
    Do a dry steer test. Look at the frame to see if it is cracked or if the body moves and the tires do not. If the frame is cracked get it...
  • JPNinPA
    JPNinPA replied to the thread 1986 CJ7 wondering.
  • J
    Jeepergeo replied to the thread Uncertain about purchasing.
    Jeeps TJs are great vehicles for offroad use or use in snow. If you rarely drive in those conditions, you won't get all the benefits of...
  • superj
    superj replied to the thread 1986 CJ7 wondering.
    After you get that stuff done, get it aligned and see if it helps
  • K
    Kailob posted the thread 1986 CJ7 wondering in Wrangler and CJ.
    Hello So I have an 86 CJ7, it’s lifted with more bent leaf springs and sitting on 31 inch tires I believe. Anyway when you try to drive...
  • superj
    superj reacted to TerryMason's post in the thread Uncertain about purchasing with Like Like.
    I've got an 05, and there are a couple months a year where I throw $300 - $500 in parts at it, doing all my own work. Death wobble is a...
