Latest activity
  • JPNinPA
    JPNinPA replied to the thread Another noise from under my TJ.
    Hopefully it wasn’t blocked too long. Check your fluid level. And check your trans fluid color. That’s automatic transmission fluid. And...
  • JPNinPA
    Terry. This one is for you: https://youtube.com/shorts/bIPgDUnwSrk?si=5gNjOtnxInXhbYJT Never look down on anyone unless you are...
  • J
    Jeepergeo replied to the thread Serpentine Belt issue.
    Compare the new belt to the old belt, if the same, use the new belt. Take the old belt to AutoZone and compare to the belt they list...
  • JPNinPA
    Never look down on anyone unless you are helping them up - Jesse Jackson Rear pumpkin is not in-line with axel.
  • JPNinPA
    Detailed eyes. When you problem solve daily you look at the details and question a lot. Never look down on anyone unless you are...
  • M
    mark sr reacted to TerryMason's post in the thread Another noise from under my TJ with Like Like.
    How do you know all these things? Once I took the shroud off the radiator was pretty well plugged up everywhere it covered. I took a...
  • superj
    superj reacted to TerryMason's post in the thread Another noise from under my TJ with Like Like.
  • TerryMason
  • superj
    superj reacted to JPNinPA's post in the thread I have some what is this questions with Like Like.
    Depending on what you mean by going into the headlamp harness, it could be one of two things. First, it could be powering a set of...
  • Engir
    Engir replied to the thread Serpentine Belt issue.
    This was right after I got the Jeep, the old belt was frayed on the outer edge and looked old, that is why I replaced it. When I...
  • JPNinPA
    JPNinPA replied to the thread Serpentine Belt issue.
    Is it narrower compared to the old belt? Also compare the ridges spacing, not just the width. Also, in your picture, it looks like you...
  • JPNinPA
  • Engir
    The problem is the belt is moving around on the pulleys and fraying the edges. This makes me think I need a wider belt. That is why I...
  • superj
    superj replied to the thread Serpentine Belt issue.
    I would be fine running the belt on groove thinner
  • superj
    Maybe its the headlight relay for high or low beams?
