Latest activity
  • JPNinPA
    JPNinPA replied to the thread Another noise from under my TJ.
    Check the fan too if the clutch is gone. Dont drive too long without the shroud. Or at least monitor your engine temp. Sitting at a...
  • Engir
    Engir replied to the thread Window regulator.
    The S10 and S10 Blazer are not even close. This is taken from dead Jeeps and they want $319 for it others on eBay around $250 and it is...
  • superj
    superj replied to the thread Window regulator.
    No rebuild kit but maybe a similar year chevy s10 blazer works? What does your look like? Also, the crank from a newer cherokee should...
  • Andrew Mac
    Andrew Mac reacted to TerryMason's post in the thread Finally changed out my bump stops with Like Like.
    I changed out the bump stops on my 2005 Wrangler. I think it was about time. These old ones are pretty crusty Sent from my Pixel 6a...
  • Andrew Mac
    Andrew Mac reacted to TerryMason's post in the thread Another noise from under my TJ with Like Like.
    I have brown dog extended engine mounts, so I went to roll around under my Jeep and take a look at them when I saw this. I'm...
  • Engir
    I have an 87 XJ with manual windows. My passenger front window is skipping teeth is there a rebuild kit, does someone sell them, or is...
  • superj
    superj replied to the thread Another noise from under my TJ.
    Oh, hungry fan got the shroud
  • TerryMason
  • JPNinPA
    I would check how much engine and trans movement you have under load. Stopped, foot on brake, go from drive to reverse and back while...
  • TerryMason
    TerryMason replied to the thread Weird engine noise from my TJ.
    The monkeys are satisfied (for now) - thanks for your help, that could have ended poorly. I haven't really driven it for the last...
  • TerryMason
    You guys did such a good job diagnosing the "laughing monkeys" that I'm back with another. Driving down the road in my 2005 Jeep TJ...
  • A
    aamir567 replied to the thread Ford gpw 1942.
  • superj
    superj reacted to Engir's post in the thread Front axle swap Question with Like Like.
    What I am thinking is get the front and change it to 3:07. The Front axle of the Rubicon is 30 spline as is my Dana 44 rear axle and...
  • Engir
    Engir replied to the thread Front axle swap Question.
  • superj
    superj replied to the thread Front axle swap Question.
    Yes, but if you get the axles, you will have to add leaf spring plates to the rear since all rubicons have front and rear coil springs...
