Latest activity
  • M
    mark sr reacted to superj's post in the thread got another tj with Like Like.
    The new parts jeep started today. The new fuel pump came in so we dropped it in and the jeep fired right up
  • superj
    superj replied to the thread Fuel Gauge issue.
    Dang, i just saw the little picture in the bottom of your first post. I think it is the gauge but do the test i told you. It actually...
  • superj
    To test the gauge and wire, unhook the wire from the sensor and touch it to the block when the ignition is in the run position. The...
  • Engir
    Engir replied to the thread Fuel Gauge issue.
    I am going there in the morning and plan to make sure the plug you see in the attached video is plugged in right and while I have the...
  • superj
    So its a single connwction sensor? If so. The pull the sensor and check it. It acts like its bad since it pegging to foll deflection
  • Engir
    There is only one fitting and it is only fits one way but I can check it next time I am at the garage and see if the mechanic working on...
  • Engir
    there is only one fitting and it is only fits one way but I can check it next time I am at the garage and see if the mechanic working on...
  • superj
    superj replied to the thread got another tj.
  • superj
    Yeah, something grounded since the gauge is reading pegged to full
  • M
    mark sr replied to the thread Fuel Gauge issue.
    wired up backwards ??
  • Engir
    The fuel gauge on my 1987 Jeep XJ was not working when I purchased my XJ. I did an electrical test with my multimeter according to a...
  • TerryMason
    TerryMason replied to the thread Ford gpw 1942.
    That looks like a blast. I'd have been nervous when the front end came up while climbing the hill (at 1:09)!
  • superj
    updates: i crawled under the 1k tj in search of the crank sensor and got it changed out with my youngest son. while under there i...
  • A
    aamir567 replied to the thread Ford gpw 1942.
  • superj
    superj replied to the thread NEW 32RH Transmission dipstick.
    32rh dipstick measurements 28-7/8" from what would be the top of the tube. Bottom of dipstick to minimum 1-1/4 inch Bottom of dipstick...
