I have a 94 ZJ with that came down with the rather usual door harness problem. I repaired it once with butt connectors, and it worked for a year or so. I parked the jeep for a year and then tried to get it ready for the road again. Now everything quit working. I took the harness out of the jeep completely and soldered the wires back together, adding wire where the old stuff was no good. It bench tested perfect, perfect continuity even when i moved the harness all around. When I put it back in the jeep a few things worked. a couple windows would go down but not up, the locks would not work, the mirrors would not work. When I try the windows that don't work, the dome light dims and the ABS light comes on. What does the ABS light have to do with anything? Anyone had this problem? I thought this was a simple fix, but something went wrong. Any tips would be great.
