Liftgate glass install help!
I second Bounty as I have just gone thru a "clogged cat" ordeal.  Here's what happens: there's a honeycomb type filter in your cat-verter.  When it gets old/clogged/bad it will not let your engine breathe like it should, thus decreasing your power.  Eventually, if you put enough power to it, it could break apart and pieces of that honeycomb could get lodged in your muffler.  You might hear a rattling in your muffler and/or pipe.  When the parts break loose, your engine will breathe, but they could cause blockage somewhere else.  If you have rattling, I would suggest replacing your muffler too, as it will be near impossible to get all the loose pieces out of it.  Unless you like that rattle-can sound...?  I've heard weirder.
Get a new cat.
hi-C
