TWDJ
Well, I finally got the project completed after purchasing and installing a new Kenwood 50x4 in-dash tuner/CD, 2-Infinity 4"x6" two-way speakers (in-dash) and 2 matching Infinity two-way 4" speakers (in a Sky-Pod). Some observations:
1 - The whole "speaker-in-the-dash" thing was not at all as bad as I thought. I went ahead and laid down the windshield and removed all the dash bolts/screws. This also gave me an opportunity for checking the WW wiper motor and see if there was evidence of any leaks. This allowed me (meathooks for hands) to have all the room necessary to move around.
2 - The only thing in my way from the bottom (driver's side) was the E-brake release and the door light. The light I never have connected anyway so it was removed. The E-brake handle was rotated 90* and was not an issue after that.
3 - I went ahead and spiced the B+ and accessory (Acc) circuit together for the radio. The directions say you can run the battery dead if you connect Acc direct to B+, which means I need remember to turn the radio off. I've already been trained to pick up my dirty clothes, put my dishes in the dishwasher and put the seat down ... this should be no more difficult.
4 - There was never a clock installed in this rig, so the under-dash fuse panel actually has a female spade connection marked "clock" that is always hot. By putting a spade connector on the fused B+/Acc wires, I found a convenient and positive power source. The Ground I ran to the door strap connection by the driver as that was the best connection I could find.
5 - The Sky-Pod is way cool. I'm running the front channels to the in-dash speakers and the rear to the Sky-Pod. I reversed L and R on the Sky-Pod so it is almost like each person in the front seat has their own headphones. The folks in the back get good volume and almost a mono blend but, as we rarely carry passengers, this is no problem.
Took a drive last night. It's not a thumper but WOW ... sounds way better than EVER before. Glad I took the plunge. Thanks for all the really great info on this process and I hope this gives the next guy some confidence that it is a VERY doable project.
