The only winch that uses a different winch plate is the 8274. Almost every other winch made uses a standard mounting pattern. Most of the times the winch plates are vehicle specific. CJ's are different than YJ's, YJ's are different than TJ's, and TJ's are different than JK's. YJ plates and TJ plates are usually the same plate with one extra hole drilled. The 8274 uses a face mount instead of a foot mount.
