X xjman99 New member Jan 24, 2011 #1 I have a 99 xj and every time I turn left or some times right I get a whining noise in the rear end and I was wanting to know if that could be the rear bearings going out or if that is something else
J Jeepergeo Member Jan 24, 2011 #2 If you have normal mileage for a 99, you could very well be up against wheel bearing wearing out, even more so if you have big wheels and tires.
X xjman99 New member Jan 24, 2011 #3 Jeepergeo said: If you have normal mileage for a 99, you could very well be up against wheel bearing wearing out, even more so if you have big wheels and tires. Click to expand... Okay I thought so cool thank you now is the bearing on the axle shaft it self
T tow_hook New member Jan 24, 2011 #4 xjman99 said: Okay I thought so cool thank you now is the bearing on the axle shaft it self Click to expand... spin it and check for noise, or play with the trans in netural. or at low speeds on jack stands..
