The ignition switch should be at the base of the steering column. You'll see a square connector with some 12gauge wires connected to it. There will also be a control rod that runs up the steering column to where the key goes in. Be sure you get a switch that corresponds to the type of column you have (tilt or non-tilit). :mrgreen:
-Nick :!:
