Hey gang,
My 91 XJ 223k mi which had been running like a top lately has just started acting up. Her symptoms are wheezing and stalling and a real rough idle, I am thinking it is related to the sensors or idle control mod b/c this only happens at low speeds. However the girl has seemed awfully sluggish on acceleration recently too, its as if this problemo has gotten worse. Just to let you know in the last year she's had new injectors, fuel pump, tank, o-rings in the fuel line, and fuel filter, cap rotor plugs wires, plus a complete new cooling system. Now I did take out her thermostat last fall to try and isolate an over heat problem and never put it back in, I have noticed that she ran rougher this winter b/c of the long warm up times and cool temps that the computer read into its firing mix/order however I dont believe what with the weather turning warmer that the thermo could have anything to do w/this current problem. Thanks for your help!
KCASH
KCASH
